Explode Object component ignores blocks with invalid content
After reading this topic, I thought I should mention this problem I experienced just recently.
The file I was working with is a building which was converted from *.ifc
It contains blocks, meshes and breps. One mesh in a block is invalid.
Since I was just going to shrinkwrap all geometries in the file, I thought I would simply use the Eplode Object component. Unfortunately the component fails to output anything if a branch contains an invalid mesh.
This can be problematic on large files with a lot of geometries.
I cannot share my clients file. Here’s an example with another mesh:
block_invalid_explode_problem.gh (19.1 KB)
in this particular case you can check the mesh for degenerate faces and reconstruct the mesh
this is done by custom script (i think there’s a rhinocommon function that does that, but i forget)
double click on the c# script for details
block_invalid_explode_problem[partial_fix].gh (24.2 KB)
I think a more robust version is possible, like checking face degeneracy by tolerances, but for now, i think this stands as a proof of concept
alas, here it is
CullDegenerateFaces()
Thanks for the cull degenerate faces script.
Nevertheless I’m not sure if the current behavior of the explode component is on purpose and I’m hoping someone from McNeel can take a look.
@kike is this something for you?
one explanation i could find for that behaviour is that the meshsphere ex component create 6 different meshes
observe the seams
if you explode the baked mesh in rhino, it gives you 6 meshes
so even if you manually introduce a degenerate face in the meshsphere ex mesh, you still end up with the same seams
the real question is why the regular explode component in grasshopper doesn’t give you 6 meshes as manually exploding it in rhino
Adel, forget the mesh. Please. I’m not looking for a solution to fix the mesh.
@kike or @AndyPayne is this behaviour intended? Couldn’t the explode component output the invalid mesh?
I spoke with Kike and we both agree that it would not be the correct behavior to switch the explode component to return invalid objects. We feel that it is better to only return valid objects and make the user aware if there are invalid objects that were not exploded. To this end, the explode component will now return a warning if an invalid object is passed into the explode component with some additional information as to why that particular object was failing to return anything.
However, to ultimately get at a list of objects that represent what it is that you are after, it is possible to use a the Null Item component in tandem with a Pick N Choose component to reconstruct the list of objects. I’ve attached an example below.
block_invalid_explode_problem_AP.gh (16.8 KB)
Thanks Andy I think this is a good solution.
Hi Andy,
I don’t agree with this approach. I’m currently working with blocks that are imported from different software, and there are some invalid surfaces in the block, but I don’t care about that as 99% of the block is perfectly fine, but the component refuses to provide me with ANYTHING. (Same goes for meshes that I can often repair to be valid).
I believe the correct approach is to give the user the invalid content, but show a warning. Let me as a user decide what I want to do with the invalid content
Please please please let data pass through and avoid the assumptions of what the user needs. This is causing quite serious issues on a project I’m working on.
The example above works in Rhino 8 but fails in the current WIP
System Info
Rhino 9 SR0 2025-1-21 (Rhino WIP, 9.0.25021.12305, Git hash:master @ cab2010608ab7403034e91bd9ce8656db05706e5)
License type: Commercial, build 2025-01-21
License details: Cloud Zoo
Expires on: 2025-03-07
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA RTX A5000 (NVidia) Memory: 24GB, Driver date: 11-13-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 553.35
Secondary graphics devices.
NVIDIA Quadro K2200 (NVidia) Memory: 4GB, Driver date: 11-13-2024 (M-D-Y).
- There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-13-2024
Driver Version: 31.0.15.5335
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\Program Files\Rhino 9 WIP\Plug-ins\ConstraintsUI.rhp “Constraints UI” 9.0.25021.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25021.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25021.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25021.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25021.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 9.0.25021.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25021.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 9.0.25021.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25021.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
@Timo_Harboe_Nielsen,
We enabled exploding blocks with invalid geometry on 8.17.
But it will still fail to explode an invalid mesh into faces.
@martinsiegrist, the issue on WIP is fixed as well.
