"Explode" Objects failing with block instances
I have a collection of block instances. I am trying to access the geometry within each block. After I query the blocks from their layer and try to explode, approximately 75% of the blocks fail to explode.
The explode error is telling me
“1. Solution exception:Object reference not set to an instance of an object.”
A few details I would not expect to cause an error but in case I’m missing something…
-I have multiple blocks placed in multiple locations
-The blocks are coming from an imported Autocad dwg. import
-Is there some geometry or data type within the blocks that might be causing it to fail? I am seeing no other indication of what is wrong outside of the exception error.
Any help or some things to look for would be appreciated
Hi Dave,
I’m guessing there is a data type issue. Can you post a few of the blocks that are failing?
If there are privacy concerns you can upload here.
Thanks. I have uploaded the DWG to the link you sent me.
It looks like when I try to assign the blocks that are not exploding in the mass selection will explode when assigned separately so I assume its a bug in the “Explode Object” node and not the blocks themselves. I am wondering if it is failing when there are multiple instances of the same block in different locations? I am trying to confirm that on my end
Either way I appreciate it getting looked at.
Thanks Dave,
Please run SystemInfo in the Rhino command line and post the results. I’m not seeing the issue here in the latest build. I’ll send a link if you want to try it.
Rhino 8 SR11 2024-9-10 (Rhino 8, 8.11.24254.15001, Git hash:master @ d3c11108eae09fadc146928ba51b9b182a05303f)
License type: Commercial, build 2024-09-10
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.5
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA RTX A1000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 6-2-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 532.09
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-2-2023
Driver Version: 31.0.15.3209
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.11.24254.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24254.15001
Thanks, systeminfo look ok, video driver could use and update.
Ran the update and it appears to have worked. Thanks again
