To open, edit, create and save xlsx | csv files
Using ReoGrid
Using ReoGrid
That looks awesome! Could this be used for documentation purposes on say a small/medium architecture project?![]()
Hi, it is as describes to open ,edit create and save but not all excel functions.
Maybe you find it useful after testing, i will add it to Fennec Addon soon
When you open your CSV file where you have added four values to the second column before saving these four values show up on the third column…
Hi @nathanletwory
I will check it , maybe this is a bug
Thanks @nathanletwory , i test it again and the same error
I think this is a bug , i will contact the developer about it
The same error in their editor:
Looks like there are two bugs according to your screenshot:
The shift of values from B to C, but also the empty row 2 is missing on the right.
Yes , i hope they fix that
From their website saving to csv is not possible but they have another method to export.
Maybe i will disable this and use regular csv export in ironpython
Some options added: Merge, Unmerge, Borders… and input to create excel file.
We can add many sheets to the same files with different datas.
Hi
I try to convert the form to a component but i don’t find the right way.
Any help is very appreciated
When i use: form.Show(Grasshopper.Instances.ActiveCanvas)
I cant add values when navigating in the table (like in excel)
Using: form.ShowDialog() solve the problem but the can’t use Grasshopper in this case
Is there a way to use ShowDialog like Show(Grasshopper.Instances.ActiveCanvas)
For now this work fine:
Application.Run()
When do you think you’ll add this to Fennec?
Dan
Hi
Until i can compile it to ghpy component, right now i don’t find a way.
More options added:
Available now in food4rhino
I can’t access this for some reason.
