Every 2nd material doesn't work
Every 2nd material doesn’t work when I d&d it to an object.
Charles, run _SystemInfo and paste the results :saluting_face:
Rhino 8 SR24 2025-9-8 (Rhino 8, 8.24.25251.22001, Git hash:master @ 9cd9ffa629e499c8388777cf881c595dc6dca603)
License type: Commercial, build 2025-09-08
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9310.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-26-2025
Driver Version: 32.0.15.7216
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\7.0.1.1\XNurbsRhino8.rhp “XNurbs”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.24.25251.22001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.24.25251.22001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.24.25251.22001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.24.25251.22001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.24.25251.22001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.24.25251.22001
The materials work just fine. Remember that in Rhino 8 and earlier Rendered display mode doesn’t do glass-like materials well.
In Rhino 9 it is better.
Raytraced will show them correctly in Rhino 6, 7 and 8.
Please apologize, I didn’t express myself 1000% correctly.
I’ll try to be more precise now.
Of course you are right, the materials render fine.
Except in Rendered display mode.
In Rhinoceros Version 8:
Every 2nd material, that I drop to an object, doesn’t show correct in Rendered display mode.
I don’t see a real difference between the materials except color.
In Rhinoceros WIP:
I see the same bug when Direct3D is active.
It works as expected when OpenGL is active.
Do you still think all is fine?
I believe transparency for Direct3D in Rendered mode is still being worked on in Rhino 9.
As said, Rhino 8 and earlier will not show transparent objects correctly.
Yes, they kind of work fine.
And I understand what you say about transparency.
I found that I was accidently right about the materials.
See video:
The 1st has a transparency of 0; it renders correct in Rendered display mode.
The 2nd has a transparency of 100, in fact it renders correct in Rendered display mode.
100%???
Now I wonder how Raytraced renders a 100% transparent material so that it is visible.
And Rhino 9 WIP, at least with OpenGL, can show a 100% transparent material in Rendered display mode, that’s not right!
Note that my materials have German names.
I didn’t edit any of the materials.
Do you see a problem?
The second one does NOT show correctly in Rendered display mode.
Opaque materials (transparency 0%) render correctly.
Still. The problem is as I stated in my first reply: transparent material (transparency greater than 0% ). Do not render correctly in Rendered display mode. But do render correctly in Raytraced and Rhino Render.
Transparency is not the proper term. It is more transmission.
In Raytraced and Rhino Render if you want to have an invisible material you’d essentially use Physically Based material and set alpha.
I don’t want an invisible material for now.
Nor a 100% transparent material.
I only want to pick a usable material from the library.
Do I expect too much?
Aha, I’d expect 100% transparency makes an object invisible.
That’s what I see in the viewport, in WIP a transparency of 100% makes the object visible.
Seems I don’t get it.
Some see him, some not.
I wonder why the 1st material is 0% and the 2nd 100% transparency.
I don’t see the sense for this setting on every 2nd material.
50% of the library materials are useless for rendering in Rendered display mode.
I only wanted to report an issue.
There is an issue.
The issue itself is 0% (or 100% ?) transparent, means some see an issue and some not. :wink:
You won, I give up.
As said, the transparent materials (100%) don’t look right in Rendered mode in Rhino 8 and earlier. But they now show up in Rhino 9 in at least OpenGL, and to some extent in Direct3D, which probably is going to get better.
In Raytraced and Rhino Render those have always shown correctly.
Transparency 0% means fully opaque, no transparency. 100% means light is let through. But the color will act as a filter. Darker colors will block more light, even with 100% ‘transparency’ (transmission).
Let me illustrate with Rhino Glass material - Glass is with 100% clarity always 100% transparent. But modulated by the color:
From left to right you see clear glass (white color), light glass with a very light orangy color (hex code #F4EFE2 ), medium glass (hex code #E9C15E) and dark glass (hex code #9A7413). All three colors are a form of orange with less and less value. You see how less light is let through.
Rhino 9 probably will be closer to that as well.
