Evaluate F(X) Expression input - Problems with Example Definition from the AAD book
Hi guys,
I am new to Grasshopper, so I have been going through the AAD Algorithms Aided Design Book by Arturo Tedeschi.
Towards the end of Chapter 2, their is a example definition that uses the Evaluate F(X) component, and it wants to input a function of X^2.
The Panel & the Expression components won’t work, and causes the script to fail.
Does anybody have any recommendations?
Thank you!!!
90|690x388
I think it’s lowercase x
Hi Michael!
I tried to change the X to an x, but It doesn’t look like anything has changed. Am I typing it in wrong?
The Evaluate F(X) component error says
  1. Parameter “Variable x” has an invalid name. Only use alphanumeric characters and don’t start with a number.
  2. Parameter “Variable y” has an invalid name. Only use alphanumeric characters and don’t start with a number.
The interpolate component error says:
  1. Insufficient interpolation points for a curve
This is what the script looks like on my computer.
I believe it is because you are using full name inputs (if I remember the issue correctly). So it is saying “variable x”
See here: Bug: Function component + Draw full names
As you said! there is indeed a strange bug when displaying names for the function component.
I started a fresh file and tried the script again. Here is a screenshot of it working :slight_smile:
Time to move forward in the book!
Thank you for your help!
To me this Bug: Function component + Draw full names didn’t work.
I solved by putting the x into brackets: (x)=6 for example, as the x is called ‘Variable x (x)’, so Variable x sounds more like a description while the function would require the (x) to work.
Hope it helps.
Thank you!
