EtoCollapsibleSection and Scrolling
Hi
Can anybody give me a hint on this ?
If I insert a Panel into a EtoCollapsibleSection and the Height of the Parent Container is
smaller than height of the panel I would expect to see a vertical scrollbar
It does not happen so instead of a Panel I have inserted a Scrollable
EtoCollapsibleSection Section;
Scrollable scroll_panel;
Section.Content = scroll_panel
Even in this case No vertical scrollbar appears, Horizontal Yes, Vertical No
Now all this seems a Bug to me, I am used to Qt where all this stuff was quite automatic and simple
Gerry
Nobody ???
EtoCollapsibleSection seems to be rhino control no info is available anywhere
Gd
@curtisw - is this something you can help with?
This image to show how a panel is unusable
without a vertical scroll bar
I have seen other issues with the EtoCollapsibleSectionHolder not updating vertical size
so there is something wrong with this
gerry
In any case as a partial solution inserting the control on a splitter
makes it work. So it seems the best way to go at the moment
gerry
Hm, I’m not entirely familiar with the EtoCollapsibleSectionHolder infrastructure. @JohnM and @maxsoder would probably know more of how to get the sections to automatically grow.
As for this particular issue, I would recommend one of the following:
  1. Set the height of the TreeGridView to something reasonable.
  2. Put the TreeGridView in an expandable/scaled row so that its height takes up only the available space.
Either of these options will make the TreeGridView present its own scrollbar, which is often a better experience for users as then the other elements on the panel will still be visible.
Hope this helps.
I tested this and I think it is a bug in the Holder. I made a fix for it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-61564
The fix will be in v7.2.
