Eto macOS - Eto.Forms.ImageListItem issue
problems 3 Eto.Forms.ImageListItem
DropDown dd = new DropDown() { ID = Guid.NewGuid().ToString(), };
            int sizz = 40;
            DA.GetData(6, ref sizz);
            foreach (string opt in opts)
                System.Drawing.Bitmap original = (System.Drawing.Bitmap)System.Drawing.Image.FromFile(opt);
                System.Drawing.Bitmap resized = new System.Drawing.Bitmap(original, new System.Drawing.Size(sizz, sizz));
                System.Drawing.ImageConverter converter = new System.Drawing.ImageConverter();
                byte[] bb = (byte[])converter.ConvertTo(resized, typeof(byte[]));
                Image image = new Bitmap(bb);
                var item = new ImageListItem();
                item.Image = image;
                item.Text = Path.GetFileNameWithoutExtension(opt);
                // Add the item to the DropDown list
                dd.Items.Add(item);
I’m having trouble getting the Image. :thinking:
Hi @taraskydon,
Can you provide code to a working sample, that we can run here, that demonstrates the issue?
Thanks,
– Dale
The problem here was these examples. replacing them with Rhino.UI.EtoExtensions.ToEto helped to load the image. it’s a macOS problem.
// System.Drawing.ImageConverter converter = new System.Drawing.ImageConverter();
// byte[] bb = (byte[])converter.ConvertTo(resized, typeof(byte[]));
 Bitmap rImage = Rhino.UI.EtoExtensions.ToEto(resized);
examples
Uploading: ToolPanel.zip…
ToolPanelTESTui.rhp (207 KB)
