thomas
(Thomas)
February 18, 2016, 4:26pm
1
So, I have a nice little Eto dropdown that should get populated from a list with custom objects.
The following code works in Windows (RH6), but fails in Mac. In the latter, instead of text values, the control shows the object type.
class MyObject
public string Key { get; set; }
public string Name { get; set; }
List<MyObject> myObjects = new List<MyObject>();
// ... fill list
var selector = new DropDown
DataStore = myObjects,
ItemKeyBinding = Binding.Delegate<myObject, string>(a => a.Key),
ItemTextBinding = Binding.Delegate<myObject, string>(a => a.Name),
In Mac, the selector shows the type name instead of the name values:
MySolution.MyObject
MySolution.MyObject
MySolution.MyObject
MySolution.MyObject
MySolution.MyObject
Is this a bug or am I missing something?
menno
(Menno Deij - van Rijswijk)
February 18, 2016, 8:06pm
2
It sounds like a bug to me, but you’re probably better off reporting it directly on GitHub
https://github.com/picoe/Eto/issues as it seems not Rhino-related.
dale
(Dale Fugier)
February 18, 2016, 8:45pm
3
@curtisw , is this something you can confirm (or deny)?
menno
February 18, 2016, 9:14pm
4
Thinking about it, I knew I ran into this recently, and it is already in the issues list
The solution is to override the ToString() for the display code; in your case you may have to do some more to get it right.
thomas
(Thomas)
February 19, 2016, 1:27pm
5
Thank you, Menno.
For the time being, I was able to make a rather clumsy workaround by assigning the string values directly via selector.Items.Add(...)
curtisw
(Curtis Wensley)
February 19, 2016, 8:58pm
6
Yeah this is a known problem as @menno pointed out. I didn’t know it had the same problem on OS X, so thanks for letting me know!
I’ve updated the issue to reflect this.
Thanks!
Curtis.
