Hello!
I am trying to crate a small window with an Eto GridView in python. The code compiles and the three rows that i am trying to show show up but there the values does not show.
I tried in a lot of different ways (also by creatig a custom class) but it does not work. It always only shows up blank lines. Also when printing grid_view.DataStore is an empty list .
I am on a mac intel
Thank’s in advance
Cheers
Eric
self.form = forms.Form()
self.form.Resizable = True
self.form.Width = 200
self.form.Height = 400
# create grid view and columns
self.grid_view = forms.GridView()
self.grid_view.DataStore = (['one', 'two'],
['a', 'b'],
['alpha', 'beta'])
print(self.grid_view.DataStore)
self.columnA = forms.GridColumn()
self.columnA.HeaderText = "A"
self.columnA.Editable = False
self.columnA.DataCell = forms.TextBoxCell(0)
self.grid_view.Columns.Add(self.columnA)
self.columnB = forms.GridColumn()
self.columnB.HeaderText = "B"
self.columnB.DataCell = forms.TextBoxCell(1)
self.grid_view.Columns.Add(self.columnB)
self.form.Content = self.grid_view
self.form.Show()
Hi @Eric_Norman_Gozzi
import Rhino
import Eto.Forms as forms
import Eto.Drawing as drawing
class GridItem(object):
def __init__(self, col_a, col_b):
self.ColumnA = col_a
self.ColumnB = col_b
form = forms.Form()
form.Title = "Grid View Example"
form.Width = 300
form.Height = 400
columnA.DataCell = forms.TextBoxCell("ColumnA")
grid_view.Columns.Add(columnA)
columnB.Editable = False
columnB.DataCell = forms.TextBoxCell("ColumnB")
grid_view.Columns.Add(columnB)
data = [
GridItem('40', 'Apples'),
GridItem('30', 'Bananas'),
grid_view.DataStore = data
form.Content = grid_view
form.Show()
There were a bunch of mistakes, hope this clarifies your doubts,
Farouk
@farouk.serragedine thank’s a lot for the answer. Your solution works but I have the same issue: the form, the grid view and the rows they all appear, but not the values inside the single rows. The table is just empty. I think there is a problem with the DataStore attribute of the GridView, it somehow fails to collect the data.
Thank’s a lot for the help anyway.
This is my output
Gijs
(Gijs de Zwart)
October 7, 2025, 4:57pm
6
@Eric_Norman_Gozzi this seems an issue with Python3 rather than a mac issue
If you save your code as python2 you will find it works.
RH-89785 Gridview doesn’t work correctly in Python3
Henry_Wede
(Henry Wede)
October 7, 2025, 11:30pm
7
Not asking you to predict the future, but how long do these fixes usually take?
Using Python 2 isn’t a viable option.
Thanks
Gijs
(Gijs de Zwart)
October 8, 2025, 8:14am
8
Anywhere between 1 day and 10 years.
But joking aside, I suspect this can be fixed fairly quickly.
Thank’s a lot for the answer.
Gijs
(Gijs de Zwart)
October 8, 2025, 2:52pm
10
Not sure about fairly quickly, since the release target is set to 9.0,
But in the meantime I found
Hi all,
Trying to create a simple ETO modeless dialog in Rhino 8 and Python 3 with a GridView.
I cannot seem to get the DataStore contents to render in the table. The data does exist, and adding a ClickEvent shows that data is stored in the element.
Minimal code example below, with the ClickEvent which prints cell content clicked to the Rhino commandline.
Any ideas to what I am doing wrong?
I did have to change the DataStore from a list of lists to a list of tuples to make it work from Iron…
Hey @Eric_Norman_Gozzi ,
I’ve written about Eto Cells and touched on Grid Views here → Rhino - Cells , you’ll be able to see how to make a GridView work in python.
@CallumSykes Thank’s a lot!
It is exactly what I needed
