[Eto feature request] Event for light / dark mode switching
I’ve been implementing my plugin for the macOS dark mode. I notice there’s no event of system switching between light & dark mode, therefore the component icons in the ribbon stay as when GH is loaded.
An event can be very helpful as Rhino itself supports switching.
There is not currently, but I’ve added this post to the YouTrack, which I’ve also made visible
https://mcneel.myjetbrains.com/youtrack/issue/RH-65471/Add-AppearanceChanged-event-to-Eto-Application-so-system-appearance-changes-can-be-tracked-and-UI-updated
in case you’d like to know how to listen for the event in Windows:
In Rhino 8, there is also the Rhino.UI.ThemeSettings.ThemeChanged event, which works on both Windows and Mac.
