I’m having these errors on the command line in Rhino Mac. There don’t seem to be other issues happing.
17/02/2025 16:05:03|Fatal|<>c__DisplayClass9.<ReadBytesAsync>b__8|System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer.
---> System.Net.Sockets.SocketException (54): Connection reset by peer
--- End of inner exception stack trace ---
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken)
at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token)
at System.Net.Security.SslStream.EnsureFullTlsFrameAsync[TIOAdapter](CancellationToken cancellationToken)
at System.Runtime.CompilerServices.PoolingAsyncValueTaskMethodBuilder`1.StateMachineBox`1.System.Threading.Tasks.Sources.IValueTaskSource<TResult>.GetResult(Int16 token)
at System.Net.Security.SslStream.ReadAsyncInternal[TIOAdapter](Memory`1 buffer, CancellationToken cancellationToken)
at System.Threading.Tasks.ValueTask`1.ValueTaskSourceAsTask.<>c.<.cctor>b__4_0(Object state)
--- End of stack trace from previous location ---
at System.Threading.Tasks.TaskToApm.End[TResult](IAsyncResult asyncResult)
at WebSocketSharp.Ext.<>c__DisplayClass9.<ReadBytesAsync>b__8(IAsyncResult ar)
Object reference not set to an instance of an object.
at Rhino.UI.Internal.OptionsPages.UnitsSettingsViewModel.Initialize() in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/DotNetSDK/Rhino.UI/Internal/OptionsPages/UnitsSettingsViewModel.cs:line 36
at Rhino.UI.Internal.OptionsPages.UnitsSettingsViewModel..ctor(OptionsPageHost host, UInt32 doc_sn, Boolean isPageSettings) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/DotNetSDK/Rhino.UI/Internal/OptionsPages/UnitsSettingsViewModel.cs:line 27
at Rhino.UI.Internal.OptionsPages.UnitsSettingsTabPage..ctor(OptionsPageHost host, UInt32 doc_sn, Boolean isPageSettings) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/DotNetSDK/Rhino.UI/Internal/OptionsPages/UnitsSettingsPage.cs:line 278
at Rhino.UI.Internal.OptionsPages.UnitsSettingsPage..ctor(OptionsPageHost host, UInt32 docRuntimeSerialNumber) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/DotNetSDK/Rhino.UI/Internal/OptionsPages/UnitsSettingsPage.cs:line 252
at Rhino.UI.Internal.OptionsPages.UnitsSettingsPage.<>c__DisplayClass0_0.<NewHost>b__0(OptionsPageHost host) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/DotNetSDK/Rhino.UI/Internal/OptionsPages/UnitsSettingsPage.cs:line 26
at Rhino.UI.Internal.OptionsPages.OptionsPageHost.get_PageControl() in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/DotNetSDK/Rhino.UI/Internal/OptionsPages/OptionsPageHost.cs:line 68
at Rhino.UI.RhinoPageHooks.RhinoPageShowHook(IntPtr constPointer, Guid runtimeId, Int32 value) in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/DotNetSDK/rhinocommon/dotnet/rhino/rhinosdkpages.cs:line 190
17/02/2025 16:37:57|Fatal|<>c__DisplayClass9.<ReadBytesAsync>b__8|System.IO.IOException: Unable to read data from the transport connection: Connection reset by peer.
