Hello -
I am having an issue where Rhino 8 crashes when invoking the settings window. Running an M1 Max with 32GB RAM & Sonoma 14.5. Report below, any help is appreciated. Crash report is attached.
Thanks,
240610_crash_report.pdf (194.5 KB)
Hello -
Thanks,
Hi Michael -
Thanks for sending in crash reports.
Please run the Rhino SystemInfo command and copy-paste the output here.
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15002, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
Apple macOS Version 14.5 (Build 23F79) (Physical RAM: 32Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: MacBookPro18,2
Language: en-US (MacOS default)
Apple M1 Max (OpenGL ver:4.1 Metal - 88.1)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 21845 MB
Graphics: Apple M1 Max
Displays: Unknown (109dpi 1x)
Graphics processors
Apple M1 Max
DELL U3419W (3440 x 1440 @ 60.00Hz)
USB devices
Generic: USB Storage
Logitech: Zone Wireless
Logitech: USB Receiver
Elgato: USB Audio
3Dconnexion: SpaceNavigator
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Library/Chaos/Enscape/Enscape.Rhino.Plugin-net48/Enscape.Rhino7.Plugin.dll âEnscape.Rhino7.Pluginâ 0.0.24138.1238
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp âRhinoCyclesâ 7.37.24107.15002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp âSnapshotsâ 7.37.24107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp âGrasshopperâ 7.37.24107.15002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp âPanelingToolsâ 7.37.24107.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp âAnimationToolsâ 7.37.24107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp âCommandsâ 7.37.24107.15002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework âRenderer Development Kitâ 7.37.24107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp âRDK_EtoUIâ 7.37.24107.15002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp âDisplacementâ 7.37.24107.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoLabsTools.rhp âRhino Labs Toolsâ 7.37.24107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp âRhino Renderâ 7.37.24107.15002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp âIronPythonâ 7.37.24107.15002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp âLegacy Rhino Renderâ 7.37.24107.1002
Can you repeat with Enscape removed?
The systemInfo you posted is for Rhino 7.
@Japhy - Sorry wrong window! Also, FWIW running the Plugin Manager command crashed the app as well. I manually unloaded Enscape from the plugins folder. SystemInfo below. Thanks!
Rhino 8 SR8 2024-6-11 (Rhino 8, 8.8.24163.12482, Git hash:master @ ded4d86ca901dbeaf13ee84f79b3e91b22da4880)
License type: Commercial, build 2024-06-11
Apple macOS Version 14.5 (Build 23F79) (Physical RAM: 32GB)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
USB devices
Elgato: USB Audio
Bluetooth devices
None
None
Third party plugins
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework âRenderer Development Kitâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp âCommandsâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp âSnapshotsâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp âImport_OBJâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp âexport_xamlâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp âQuadRemeshâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp âexport_OBJâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp âRDK_EtoUIâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp âImport glTFâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp âShrinkWrapâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp âExport SVGâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp âExport glTFâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp âMeshCommandsâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp âExport_DAEâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp âPDF Exportâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp âIGES Export Plug-inâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp âImport_SVGâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp âBlockEditâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp âExport_AMFâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp âRhino Renderâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp âImport_DSTâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp âPLY - Polygon File Format Exportâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp âImport_AMFâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp âRhinoCyclesâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/PlugIns/export_SKP.rhp âSketchUp Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_UDO.rhp âMoray Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_RAW.rhp âRAW Triangle Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_USD.rhp âExport USDâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_DGN.rhp âMicroStation file import: import_DGNâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_E57.rhp âE57 Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VRML.rhp âVRML Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp âAnimationToolsâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_modelio_macos.rhp âModel IO Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_WAMIT.rhp âWAMIT importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp âNamed Positionâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_SKP.rhp âSketchUp Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp âSectionToolsâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RAW.rhp âRaw Triangles Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/MPlane.rhp âMPlaneâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_XGL.rhp âXGL Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp âLegacy Rhino Renderâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CD.rhp âCult3D Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_LWO.rhp âLightwave Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SLC.rhp âSLC Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_3MF.rhp âimport_3MFâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STEP.rhp âSTEP Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3MF.rhp âexport_3MFâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_WAMIT.rhp âWAMIT Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SLC.rhp âSLC Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_OFF.rhp âOFF Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Squish.rhp âSquishâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X_T.rhp âParasolid Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp âRhino Bonus Toolsâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp âRhino Labs Toolsâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_M.rhp âImport_Mâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_X.rhp âX Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_IGES.rhp âIGES Import Plug-inâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_AI.rhp âAdobe Illustrator Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp âAutoCAD file export : export_ACADâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp âDisplacementâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_LWO.rhp âLightwave Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SAT.rhp âACIS Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CSV.rhp âComma Separated Value Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PDF.rhp âPDFReaderâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STL.rhp âSTL Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VDA.rhp âVDA Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp âSTEP Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_FBX.rhp âExport_FBXâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SolidWorks.rhp âSolidworks Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STL.rhp âSTL Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RIB.rhp âRenderman Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_FBX.rhp âImport_FBXâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_Points.rhp âPoints Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VDA.rhp âVDA Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp âAutoCAD file import: import_ACADâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X.rhp âX Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/CreaseAngle.rhp âCreaseAngleâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3DS.rhp â3D Studio Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PLY.rhp âPLY - Polygon File Format Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshTools.rhp âMeshToolsâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_Points.rhp âPoints Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp âPanelingToolsâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshFromPoints.rhp âMeshFromPointsâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VRML.rhp âVRML/X3D Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_GTS.rhp âGTS Triangle Importâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp âSolidToolsâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_GTS.rhp âGTS Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_POV.rhp âPOV-Ray Exportâ 8.8.24163.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp âIronPythonâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp âGrasshopperâ 8.8.24163.12482
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp âRhinoCodePluginâ 8.8.24163.12482
@Michael_Suriano can you please share the file settings-Scheme__Default.xm that lives at ~/Library/Application\ Support/McNeel/Rhinoceros/8.0/Plug-ins/RhinoCycles\ \(9bc28e9e-7a6c-4b8f-a0c6-3d05e02d1b97\)/settings (the tilde means your home folder).
edit:
please also run the non-autocompleting Rhino command RhinoCycles_ListDevices and copy the result that appears in the command history panel. Mine gives
Command: RhinoCycles_ListDevices
We have 2 devices
Device 0: CPU > Apple M2 Max > 0 | False | Cpu | GPU: False
Device 1: METAL_Apple M2 Max (GPU - 30 cores) > Apple M2 Max (GPU - 30 cores) > 0 | True | Metal | GPU: True
@nathanletwory - including a screenshot at location you specified. I see RhinoCycles for Rhino 7 (no *.xm file inside), but not Rhino 8. Additionally, running the command you specified crashed Rhino 8. I ran the same command in Rhino 7 and got the below info.
Device 0: CPU > VirtualApple @ 2.50GHz > 0 | False | False | CPU
Thanks for the help.
Can you run RhinoCycles_SelectDevice and then enter 0 as input, then please restart Rhino and try going to the settings page again through pluginmanager.
@nathanletwory, Rhino 8 crashes immediately when this command is executed, so I am unable to get into any other menu or setting.
Again, running in Rhino 7 for comparison that command returns:
Device 0: CPU (VirtualApple @ 2.50GHz)
User selected device 0: ccl.Device: VirtualApple @ 2.50GHz (CPU), Id 0 Num 0 Name CPU DisplayDevice False AdvancedShading False
I donât know currently what this all means. I havenât seen a VirtualApple before, and I have no clue as to what is going on.
I tested on my M1 and that works just fine, although there I have a CPU and a Metal device.
Appreciate the help regardless.
Iâm asking @dan with the same hardware to see if they can reproduce.
@Michael_Suriano just for the record: when you try the settings is this with Rhino just restarted - no documents open at all?
@nathanletwory yes, I have tried it from a fresh session both with an existing model file, but also a new âemptyâ file.
With all other documents completely closed? Just making sure, since on the Mac it is still possible to have multiple documents open in the same Rhino instance whereas on Windows that is not possible.
correct
I donât know yet why the error happens, but Iâll have a stop-gap solution in the very least.
I have logged the issue here: RH-82565 System.NullReferenceException: Object reference not set to an instance of an object.
