I think this started when I updated to Rhino 7. Any hints on how I can solve it (without reinstalling everything)?
Thanks
Is this error happening while opening a file or opening grasshopper?
You did work with GH on rhino 6? How many plugins for grasshopper were you using?
PS
If the problem is just at loading grasshopper, there is the command “GrasshopperLoadOneByOne” on rhino.
Run it and try to skip plugins and see if the normal GH loads correctly.
Then try again and load some plugin. Etc etc…
