Error with Plugin
I got this error when I installed plugin.
Could anyone tell me how to fix this?
Best,
Gen
I am currently working on fixing import_3dm for Blender 4.0 and 4.1. The API changed (yet again), which breaks the add-on. It will work in pre 4.0.
Thank you for the reply.
pre4.0 means any version before 4.0?
Yes, I know it at least works with Blender 3.5
Sorry but I had the same error.
I reinstall Blender3.5 and installed Plugin( import_3dm-v0.0.10-py3_9-macos-intel.zip)
Any way to solve?
Did you follow and read all instructions? For version v0.0.10 you need to restart Blender and then enable the addon again.
Yes, I did and I got this error.
I don’t know why.
Right, for Blender 3.5 you need the ZIP file with py3_10 in the name. If you’re on an Intel Mac that means https://github.com/jesterKing/import_3dm/releases/download/0.0.10/import_3dm-v0.0.10-py3_10-macos-intel.zip . If however you’re on an M1, M2 or M3 you need https://github.com/jesterKing/import_3dm/releases/download/0.0.10/import_3dm-v0.0.10-py3_10-macos-arm.zip, assuming you also have the Apple Silicon version of Blender 3.5
Thank you for telling the order, but I got an another error.
Looks to me that you should install the other version. If you used the macos-intel package on the first try use the macos-arm instead, and vice versa.
Okay, will do. Thanks for your patient and kindness.
Thank you so much Nathan.
It looks like the issue is solved.
I appreciate your kindness and support.
You’re welcome, enjoy Rhino and Blender :slight_smile:
Please check out
