I am unable set Top Constrain parameter for a Wall.
It needs ElementId but we have Int… how do we get ElementId?
also maybe you can allow 0 string to automatically cast to number
Since ParamValue should take different types now is too picky.
In the first case you can put a level param between the picker and the ParamValue.
But give it by done.
Hi, I have a similar problem trying to set the top constraint level of a wall using set element parameter. I get this error text : “RhinoInside.Revit.GH: Failed to assign an element from a diferent document”
I never had this error before so i guess it has something to do with the v0.0.7683.19842 update ?
I’m running into the same error here, how can I apply a Top Constraint to a wall?
