Error on process start: The system cannot find the file specified
Error
My RhinoCommon plugin is executing an external executable. I don’t receive any error while debugging the plugin locally.
But when I push the plugin to Rhino3D server and try to download, install, and run it, I receive this error:
Finite elements…
Code
Here is the code to execute the external executable:
            RhinoApp.WriteLine("Finite elements...");
            Helper.RunLogicWithLog("finite_elements.exe", args, runFEA);
            return Result.Success;
        public static void RunLogicWithLog(string exePath, string args, PostProcess pp)
            cmd = new Process();
            try
                cmd.StartInfo.FileName = exePath;
                cmd.StartInfo.Arguments = args;
                cmd.StartInfo.UseShellExecute = false;
                cmd.StartInfo.CreateNoWindow = true;
                cmd.StartInfo.RedirectStandardOutput = true;
                cmd.StartInfo.RedirectStandardError = true;
                cmd.StartInfo.RedirectStandardInput = true;
                cmd.EnableRaisingEvents = true;
                cmd.OutputDataReceived += new DataReceivedEventHandler(cmd_LogReceived);
                cmd.ErrorDataReceived += new DataReceivedEventHandler(cmd_LogReceived);
                cmd.Exited += new EventHandler(cmd_Exited);
                cmd.Exited += new EventHandler(pp);
                cmd.Start();
                // Begin asynchronous log.
                cmd.BeginOutputReadLine();
                cmd.BeginErrorReadLine();
            catch (Exception ex)
                RhinoApp.WriteLine("Error on process start: {0}", ex.Message);
Executable location
I double-checked the plugin installation. I can confirm that the external executable is actually next to my plugin RHP file:
Question
I have the external executable next to my RHP file. So, why it cannot be found?
just guessing:
StartInfo also has a WorkingDirectory
maybe check / set this ?
maybe create a full path with Reflection - see this stackoverflow article
Hi @Megidd,
Does this help?
public class TestMegidd : Command
  public override string EnglishName => "TestMegidd";
  private string AppName => "finite_elements.exe";
  private string AssemblyDirectory
    get
      string codeBase = Assembly.GetExecutingAssembly().CodeBase;
      UriBuilder uri = new UriBuilder(codeBase);
      string path = Uri.UnescapeDataString(uri.Path);
      return Path.GetDirectoryName(path);
    var dir = AssemblyDirectory;
    RhinoApp.WriteLine(dir);
    var path = Path.Combine(dir, AppName);
    RhinoApp.WriteLine(path);
    if (File.Exists(path))
      // Run external process
– Dale
