I am interested in running Rhino 5 remotely using a batch file. Here’s what I need to do with one batch file:
- Launch Rhino 5
- Run a c# script (the command “RunScript”)
- Exit Rhino
The c# script makes a new text file. I can work out how to run Rhino via a batch file, but not run the script.
I trying to use the “/runscript” command, but I get an error “The system cannot find the file specified”
This code works good:
ProcessStartInfo start = new ProcessStartInfo();
start.FileName = "C:\\Program Files\\Rhinoceros 5 (64-bit)\\System\\Rhino.exe";
start.WindowStyle = ProcessWindowStyle.Hidden;
start.CreateNoWindow = true;
start.UseShellExecute = false;
int exitCode;
try
using (Process proc = Process.Start(start))
proc.WaitForExit();
exitCode = proc.ExitCode;
but if I add then “/runscript” command, get the error “The system cannot find the file specified”
start.FileName = "C:\\Program Files\\Rhinoceros 5 (64-bit)\\System\\Rhino.exe /runscript=\"TestWriteFile\"";
Thanks very much, if you need any specifics let me know.
