Error message when installing Karamba
Hey!
I have a problem, I wanted to install the latest Karamba Version, but now i get the following Error message, when opening Grasshopper.
Exception System.IO.FileNotFoundException:
Message: Die Datei oder Assembly “System.Runtime, Version=7.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a” or a dependency on it was not found. The system cannot find the file specified.
I tried installing via the Packet Manager first, that did not work, so i installed it from Food4Rhino. Has somebody faced similar problems. Do you have ideas, what i need to do?
Thank you!!
Hi, please see 4.1.4: Runtime Errors | Karamba3D v3
There is an issue with .dll
