It seems that the Dot bake has a little issue : Dots which don’t have a “Point” input are nevertheless baked at the Origin (0,0).
The expected behavior is that when there is no “Point” input, no dot is created :
Regarding the attributes, I’m not finding the same functionnality as with Elefront : the properties I need to retrieve are those of the objects inside the blocks, and not the attributes of the block instances :
oh come on, you can handle that yourself with a dispatch or something. Point3ds are not nullable in rhinocommon so null points become 0,0,0.
I was also wondering if I could use the “Name” filter instead of the filtering mecanism that you propose
No - object names and block definition names are not the same.
try this… there are two approaches, one that duplicates work by getting the keys/values multiple times (once for each instance of the block) and another that is more components but likely more efficient (only getting attributes/geometry for one instance per block name)
Dispatch is a pain because it only works with a single toggle.
This is not so easy : when there is no data at all for the “Point” input, any component you put after that will just turn orange complaining that there’s no data.
How do you turn that into a “true” or “false” ? I know there’s a funky workaround, but I can never remember what it is…
In any case, if you consider adding a dot bake, it would be convenient to manage this inside the component.
Ah, of course… May I suggest a bit of disambiguation here ?
Maybe labeling the inputs or outputs “Block name” in one case , and “Rhino name” in the other.
Thanks for the Block stuff, I’ll test it, but I need to catch a plane at present.
use the “null item” component with “dispatch multiple” from human for an easy solution… - can even fold everything into a cluster for re-use if you want
I do not assign user texts to the blocks, but rather the objects within the blocks.
This is why your definition outputs no result with the attached example.
Time to update my "Human.gha" ? Edit : just downloaded the latest version for V6 : same problem ; I think that’s the version I had.
Then, I feel that this is not going to work anyways, because I need to reference blocks which are nested inside others.
If I filter blocks through the “Block Name Filter” of the Human "ExplodeBlock component, I can only reference blocks which have an instance in the model, but if they are nested inside others, they are not found.
The elefront component "Reference Block By Name" will reference the block definition even if there are no actual occurences in the model. EDIT : in fact, no : the Elefront component can only see referenced blocks, but there is an option to find blocks which are nested within others. Therefor, it can reference a block by name, even if it is not at the top level :
This component works, and it is very efficient because it doesn’t require to first reference all the blocks in the model and then filter them by name !
Yet, there is definitely something fishy with the “attribute” output of the “ExplodeBlock” component, as you can see here (and with the files I added in my previous message) :
that’s odd. when I open the TEST FILES.rar you sent and change the block name filter to Block 01, I get user data back. Maybe you have an odd version of Human? this is the one I have (for rh6 only!) Human.gha (416 KB)
in any case glad the script suits your needs. I’ll probably add to human eventually…
In fact this still produces unwanted dots at the origin.
I didn’t see them at first because indeed, they have no text, so they are tiny, but they are here and it’s quite troublesome.
Any idea how to stop those critters from popping up into existence ?
lefront does that by design as far as I am aware. If you are baking something and already referencing it in the same definition you will get this error. Otherwise you would create a loop.
