I’m trying to write a python component that imports geometry from one or more Rhino files. It mostly works, except before completing, the component throws a series of “Object Expired During a Solution” errors. Once I close all the error boxes, the import succeeds as expected. I attached the user object and screenshots of a few of the errors here. There are no infinite loops in my code, as far as I can tell. Does anyone know why this is happening?
Batch Import.ghuser (3.1 KB)
This doesn’t require an infinite loop, it just means you modified some objects from inside a solution (where your script code runs).
The usual fix here is to schedule another solution using GH_Document.ScheduleSolution(callback)
, and then make your changes from within the callback.
Another approach might be handling the SolutionStart
event and making changes there.
Hmm… I don’t think I understand. I’m not sure where objects are being modified, so I tried simplifying the component to just import Rhino files into a new Rhino file (the geometry does not enter the grasshopper script space):
def importRhinoFile(self, fileNames, sourcePath):
#file import
for fn in fileNames:
thisFilePath = os.path.join(sourcePath,fn)
importCommandString = '_-Import "' + thisFilePath + '" _Enter'
imported = rs.Command(importCommandString, echo=False)
if not imported:
print "there was a problem with file: " + fn
return
As I understand it, I’m modifying objects in the Rhino document space but not the grasshopper space. Unfortunately, the same error(s) still pop up. I’m not sure where I would put GH_Document.SolutionStart() to fix the error. Any pointers?
