A few of my users reported that the plugin stopped loading with the following message. This seems to coincide with Windows Update roll outs and only affects 3 out of ~600 active users.
We tried the obvious steps: reinstalling the plugin, deleting files manually, reinstalling Nvidia drivers, etc. Nothing seems to work. I can’t reproduce this on my machine.
Is there a way to diagnose this issue remotely? Since this is happening before my plugin is even loaded, I can’t generate a stack trace.
Hi. I have just changed my laptop which has AMD Ryzen on it and now whenever I try to load jifto i get the rhp loading error. Do I need to install any specific NVIDIA driver for this to work?
you must have an Nvidia GPU with latest drivers for jifto to work correctly. But the error loading plugin on startup looks more like the missing/corrupt Microsoft C++ files as pointed out by Japhy above:
Integrated accelerated graphics device with 5 adapter port(s)
Windows Main Display is laptop’s integrated screen or built-in port
Secondary monitor attached to adapter port #1
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 5-30-2025
Driver Version: 32.0.13046.11001
Z-Buffer depth: 24 bits
Total Video Memory: 32828 MB
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.70.8\net8.0-windows\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.70.8.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.40.70\net8.0-windows\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.40.70.0
I think I may know the issue. The rhp file checks for the GPU before trying to register the plugin so it just doesn’t install at all as my system is AMD.
NVidia GPU is a hard requirement and the plugin will not load without it. We might add support for other GPU vendors in the future, but this will not happen before Q1 2027.
