I am developing a .NET application that requires the use of Iron Python to read an HDF5 file format and I have found a piece of code written in C# that solve my problem.
I am using the HDF5-CSharp library HDF5-CSharp Repo but I struggling to translate the code for Iron Python.
C# CODE
public class Coordinate
[Hdf5EntryName("COORDINATES")] public double[,] COORDINATES { get; set; }
string filename = @"recorder.hdf5"; \\full path
long fileId = -1;
try
fileId = Hdf5.OpenFile(filename, true);
var result = Hdf5.ReadObject<Coordinate>(fileId, "/MODEL_STAGE[1]/MODEL/NODES");
finally
if (fileId > 0)
Hdf5.CloseFile(fileId);
IronPython CODE (it doesn’t work)
Solution exception:Property set method not found.
import clr
clr.AddReferenceToFileAndPath(r"C:\Users\FORMAT\Desktop\hdf5Test\HDF5CSharp.dll")
from System.Collections import ArrayList
from HDF5CSharp import Hdf5
filename = r"C:\Users\FORMAT\Desktop\hdf5Test\recorder.hdf5"
fileId = Hdf5.OpenFile(filename, True)
print("Group exist: {}".format( Hdf5.GroupExists(fileId, "//MODEL_STAGE[1]//MODEL//NODES")))
result = Hdf5.ReadObject[ArrayList](fileId, "//MODEL_STAGE[1]//MODEL//NODES//COORDINATES")
I attached a “recorder.hdf5” and .dll in case you want to try to help.
I have done some research around and I have (almost) made it working.
The actual problem is that I can not run the script twice and I am struggling to find a solution.
I have notice that I can just change the Class Name to run it one more time.
Error
Traceback:
line 537, in __clrtype__, "C:\Program Files\Rhino 6\Plug-ins\IronPython\Lib\clrtype.py"
line 15, in script
A possible work around is to create a different class name everytime that the script run but there should be a better way
IronPython Code that I have tried
import System
import clr
import clrtype
type_2d = type(System.Array.CreateInstance(float, 1, 1))
class Coord(object):
__metaclass__ = clrtype.ClrClass
@property
@clrtype.accepts()
@clrtype.returns(type_2d)
def COORDINATES(self): return self.__coords
@COORDINATES.setter
@clrtype.accepts(type_2d)
@clrtype.returns()
def COORDINATES(self, value): self.__coords = value
a = []
b= []
c = []
fileId = 0
fileId = Hdf5.OpenFile(r"C:\Users\FORMAT\Desktop\hdf5Test\recorder.hdf5", True)
print(fileId)
result = Hdf5.ReadObject[Coord](fileId, "/MODEL_STAGE[1]/MODEL/NODES")
try:
for i in range(1000):
a.append( result.COORDINATES[i,0])
b.append( result.COORDINATES[i,1])
c.append( result.COORDINATES[i,2])
except:
pass
