Hey everyone, is there any way that I can convert IronPython.Runtime.List to List in C#? Appreciation in advance
Hi @Tommy70101, try to cast the output object to IList<object>
first, and then you can use OfType() to convert the type.
var cList = cells as IList<object>;
var curves = cList.OfType<Curve>().ToList();
A = curves;
Or use ghpythonlib.treehelpers
to convert your Python lists to data trees.
See for instance the following post as example
Thanks a lot, Mingbo. It works! of course using System.Linq is needed
Thanks, Nathan. This post is very useful!
