I am wondering if there is a way to entangle value list components.
Basically, I have a bunch of identical value lists. They are set to drop down list and each one feeds one of the values into into another component. Whenever a new value is added to the list, I have to manually edit each instance of the dozen or so value lists to sync them up. I know if you change a cluster, other entangled clusters change too through the entangle mechanism. Is there any such thing planned for value lists or even generically for components? So when I edit one value list, all other copies get updated too.
It’d likely be pretty straightforward to script. For instance, this script might be a start, or even enough, to fulfil your requirements (e.g. it can populate value lists on the canvas with a certain Name
the Keys
and Values
Brilliant! Thanks! I’ve modified the script to run on an empty list. Also I use integer values for values so modified the script to convert to string.
