Hello folk,
Empty Rhino and Grasshoppers are taking too much space and Use the whole Memory of my computer. (please see attached
pic)Did anyone faced the same issue?
Thanks in advance,
D
Hello folk,
pic)Thanks in advance,
D
Hi - you haven’t provided more specific steps to reproduce this so I launched Rhino (6.23.20014.20381, 01/14/2020), then ran the Grasshopper
command and then checked the task manager for memory consumption over 60 seconds. On my system, there is no increase at all.
Do you still see this when you reboot your PC, launch Rhino in safe mode and then run Grasshopper?
thanks a lot Wim, yes I reboot my laptop and I am using Rhino 6, the memory usage increases way more when I ran the grasshopper, even if ‘lock solver’ mode. I need to mention that nothing else is running in my pc parallelly.
Hi -
thanks,
Hey,
ops, it’s just my habit to lock the solver first before opening any file, but anyways there is no doc opened. And the safe mode is not helping either any other option that might help?
thanks a lot
D
Hi - can you post your SystemInfo
Does the memory usage increase (visibly on the taskmanager) when rotating the viewport when using a Custom Preview component in the GH definition? If that is the case I experience a similar problem, shown in the following gif:
// Rolf
Hei Rolf - I had your report in mind but in this case it appears to happen without anything at all loaded…
yeap, as Wim said. Nothing is loaded … and the it worked normally few days ago.
Since then no change was done in the computer
You didn’t provide the SystemInfo?
