I was creating a book in 3d
I wanted to emboss a surface on that model using an image. I want to use the 3d file to process it in a CNC machine.
using a greyscale image so the blacks would emboss the surface, and white would leave it unchanged.
Under the Tabs, there is a “Render Tools” tab. If you go there, and you will see a “Apply Displacement” button. I would try that and see if it gives you a good result.
With a detailed image like that one I bet you’ll need to adjust the settings and also have a custom render mesh on the page surface. Here’s a video tutorial as well…
Hello
Here is a caption of the issue that has arrived while using the displacement feature.
As the surface is made of multiple face the texture doesnt apply uniformely,
Does someone know how to solve the issue?
