Embedding images in Rhino 7
I’m looking for a command that allows me to import an image and to embed it permanently.
I have been just pulling images into layouts to create manufacture drawings and now when I send them to my colleague the images are blank. Presumably because I need to send the pasted images with the Rhino file…which is tedious!
I’m working in Rhino 7. I have seen previous discussions that date back to 2017, so the recommended commands don’t exist. It seems like a very obvious and simple request - any help greatly appreciated!
Thanks,
Jessie
In V7, when you save a file, make sure the Save textures option is checked and all images used in the file will be embedded.
Brilliant, worked a charm, thanks John.
I’d buy you a beer if I could!
Thanks,
Jessie
V5 did not do this.
If you open a V5 file, make sure you check that box when saving it so the images will be embedded.
Hi
Also using V7 Mac but this doesn’t work for me when I’m sending files to colleges the reference images are missing it’s the same with decals which I’m also finding unstable. any help greatly received regards
Hi Zen -
Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim
here you go.
Rhino 7 SR5 2021-4-10 (Rhino 7, 7.5.21100.03002, Git hash:master @ 2cd158094b595f6400479d7cbe511454b6149527)
License type: Commercial, build 2021-04-10
License details: Cloud Zoo
Apple Intel 64-bit macOS Version 11.3.1 (Build 20E241) (Physical RAM: 48Gb)
Mac Model Identifier: MacPro7,1
Language: en-GB (MacOS default)
AMD Radeon Pro W5700X OpenGL Engine (OpenGL ver:4.1 ATI-4.4.17)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 16368 MB
Graphics: AMD Radeon Pro W5700X
Displays: BenQ PD2705Q (109dpi 1x)
Graphics processors
AMD Radeon Pro W5700X (16 GB)
BenQ PD2705Q (2560 x 1440 @ 59.00Hz)
USB devices
Generic: 5-Port USB 2.1 Hub
Apple Inc.: USB-Serial (0001)
3Dconnexion: SpaceNavigator
Apple: Headset
Apple Inc.: Apple T2 Controller
Bluetooth devices
Broadcom: Magic Mouse 2
Broadcom: Magic Keyboard with Numeric Keypad
Third party kernel extensions
com.Perfect.Driver.SystemAudioRecorder (1.0.0) 006E5F93-3F76-3B8B-BF63-0EB171665EA5
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreData.dylib
/Users/quinn/Library/Application Support/McNeel/Rhinoceros/packages/7.0/ProRender/1.0.0.6/ProRender.Mac.V7.rhp “ProRender” 1.0.0.6
/Users/quinn/Library/Application Support/McNeel/Rhinoceros/packages/7.0/AMDDenoiser/0.5.1/AMDDenoiser.Mac.rhp “AMDDenoiser.Mac” 1.0.0.0
/Applications/Rhino 7.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.5.21100.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.5.21100.3002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.5.21100.3002
Curious if a solution was found for mac users. I am currently experiencing the same issue. Thanks.
Hi Dylan - what exactly are you seeing ? Can you provide the exact steps to repeat the problem?
I work on a PC at my work office. I am looking to continue working on a rhino file at home on my Mac. I have saved the file and to the cloud however when I open it on my Mac the placed images are showing up only as surfaces. I can work around this by sending myself the images and placing them again but this becomes cumbersome after repetition.
Essentially the issue is that the ‘save textures’ checkbox does not seem to work when opening a file on Mac.
So, On Windows Rhino run Picture. Save the file, with textures. Open the file on Mac, there are no images, correct?
So far this work as expected, here.
Does this file open on Mac with an image?
Picture.3dm (368.5 KB)
I had some trouble with this when moving files from one windows machine to another, however, I found out the problem was that I was copying the table in excel and pasting into Rhino without ever saving the image as a file.
Sometimes the image even vanished from the file without changing computers, I guess when windows cleaned temporary files or something it erased the temporary file because the file name that Rhino was asking for me to find was Clipboard(randomnumbers).
Could this be causing the trouble with the vanishing textures? Can clipboard pasted images be embeded into the file?
I hope this info helps!
