Elk Rhino 7
Hi, from what i understand it might not be very compatible with it, but I really need this kind of a plugin. I wonder if there is a way to make ELK work on rhino 7?
Hi -
ELK works fine on Rhino 7 here…
that’s weird, because on my part it’s not loading. Thought it isn’t the first time I’m installing a plugin in GH. I just couldn’t manage to install it. Any tips for troubleshooting?
Hi -
When you download the zip file, you need to make sure to right away go to the properties of the file and make sure to unblock it before unzipping. There are 26 files in the zip file and you might want to try and delete the current ones on your disk before placing the new versions in the Components folder.
I’ve had no problems.
Thanks! Weirdly enough on other versions of rhino it managed to work without the whole pack, so i was using both versions of elk :slight_smile: the topography component is more reliable for me on the elk 0.6.
With the zip file at least have the elk 2 which is good as well :slight_smile:
