Elevation of column
Hello !
Can I somehow control the elevation of the columns, like the walls, windows etc.?
Beacuse I can’t find an option to do this in properties right now, and it surely would be helpfull~
The same thing applies to beams - no elevation paramater
Hi @Kida , in the case of columns, there’s no “Elevation” property as such, but you can modify it from the Z value of the columns insert point:
In the case of beams, you can control the Z value of the start and the end points of the beam path curve:
Didn’t know I can manipulate those..
Thank you!
