Problem when opening this .dwg which has nested blocks:
aergasergaergae.dwg (110.5 KB)
Lines are in blocks, but text is outside blocks.
In AutoSAD:
In Rhino:
In AutoSAD:
In Rhino:
Hi Daniel - Hm - here, the text is one block with both texts - is that much correct? The lines are in a separate block but not inserted as far as I can see - in theory, two sets of lines and the text (three blocks) are nested into another block, and we should be seeing that block, is that correct?
@Pascal yes, that is almost correct, but text objects are not a block themselves, rather they are inside a block that also contains two instances of block with the lines… in other words:
"container block"
|--text object 1 "Goods Lift"
|--text object 2 "Goods Lift"
|--block instance 1
|--lines
|--block instance 2
|--lines
For some reason like you said blocks with the lines are not inserted (they show up correctly in autocad though).
Hope that makes sense ![]()
OK, thanks, I’ll add this info to a bug track item.
RH-72439 Open DWG: incorrect blocks in Rhino
Great, thank you!
RH-72439 is fixed in Rhino 7 Service Release 29 Release Candidate
