I have a scenario where I’ve set up some data dams at various points in a (Ladybug) script. At the end of the script, I’m creating various elements in Revit. The problem is, when I disable one of the toggles, data no longer flows through, and therefore the Revit elements are deleted.
Is there an element tracking setting that will prevent this from happening?
I want to control the flow of data, but not to have the revit elements deleted.
Not really sure how that helps. Either data is going into the RIR component or it isn’t. And if it isn’t, the Revit elements will be deleted.
I’m not sure if there is even a solution, apart from disabling tracking all together. I just through I would ask the question to see if there is something I was missing.
