Can anyone else reproduce this bug in Elefront? It seems that setting a plane location as anything other that the origin point results in unexpected Block locations (it looks like the new plane coordinated are added to the old plane coordinates).
Steps to reproduce;
Open the attached Rhino and GH files
Move the Block Definition Plane - the inserted blocks keep moving to the right irrespective of where the point is moved to.
I seem to get the same error.
As soon as I connect the referenced geometry to the Define Embedded Block component, the original referenced geometry seems to be offset equivalent to the internal origin → base plane vector.
It also seems like the defined block uses {0, 0, 0} as reference plane, not the provided base plane coordinates.
This results in an offset block, when inserted into the document.
I ended up using components in Human that didn’t have the same problems. Hopefully it gets fixed in Elefront soon though as I prefer an Elefront workflow.
Yeah, me too. I hate this bug. @krahimzadeh any solutions to this? It’s been months. I really need Elefront 5 to work because of the Push Block component, it’s really helpful for fast iterations.
