Define a block by using an insertion plane in Rhino and not GH
Hi @dale @fraguada,
How do I define a block by using x and y directions and an insertion point in Rhino 7?
PS. I do know Elefront allows to add an insertion plane. I’m looking for a similar feature in Rhino.
Thank you in advance,
K
Hi @keshavanarayan82,
Instance definition geometry is always oriented on the world xy plane. Thus, if you want an instance definition to be inserted in a particular way, then you’ll need to make sure the instance definition geometry is oriented in that manner.
– Dale
OK. Sure. Thanks for the pointer.
