I try to use lightweight extrusions when possible to keep down file size but I am just now noticing that I can’t edit them the way I can solids. No MoveFace. No duplicate face border. Is this just how things work or do I possible have some corrupted objects.
I know that I can convert it to a solid but is there a way to convert a solid back into a closed extrusion?
I am working with a bunch of objects and I’m trying to keep the file size down.
Also, Jeff, if you make extrusions from curves with History enabled, you can edit he curve to change the extrusion profile. Extrusions have their own control points as well so you can change the length or orientation. That said, MoveFace, DupFaceBorder and others do work on extrusions - some, like MoveFace will convert the thing to a surface or polysurface in the process - maybe that is what you meant.
