It would be great if the NamedCplane menu showed and let you edit their coordinates. “Cplane” command lets you change them, but is limited to some extent. For example I couldn’t find a way to set only current Y value of a Named CPlane.
Hi Daniel -
Which options would you expect here? Set Origin, Set X, and Set Y?
Hi Daniel - you can always set the CPlane origin using the same input as any point input , including relative and world coordinates- is that what you mean?
I think X, Y and Z values plus rotation (e.g. pitch, roll, yaw) would be useful.
Thanks, what I couldn’t do is to set individual components of named cplanes. Sometimes you want to change only Y value and keep everything else as is
Hi Daniel - try
CPlane R0,10,0
or
CPlane RW0,10,0
or
CPlane .y pause 0
Any of that help?
Thank you, that works! Exactly what I was looking for. Can you please explain what those mean? I guess R stands for relative? How RW differs? Do these prefixes work with other commands as well? Is it documented anywhere by any chance already?
Hi Daniel - see
Pascal is right - read manual first, ask questions later.
Hello- that is not what I said. I was pointing the user at information he would find helpful.
