Eddy3d Paraview doesn't automatically load the simulation
hi @eddy3d , when I run the example template number 3 SimpleWindAnalyis, all works fine except the Paraview option.
In your video on this template, when you press the run button Paraview opens the scene. I recall when I first tried Eddy couple years back this indeed worked and the file loaded automatically. But now in the latest version it doesn’t (Eddt 3d Beta, windows 11, Paraview 5.6.2).
a .foam file is saved
PS: (the Probing component to Solve Building/Ground Mesh intersection is not flawless when i use my geometry, not sure if you noticed this in your own testing),
