I am dimension my cross sections in Rhino as a .3dm file and saving a copy as a .dxf so that my supplier can open the file. However on numerous occasions the .dxf file dimensions are changed in both dimension size, location, or precision. I’ve attached a photo that shows the dimensions changing in location and precision.
Is there a way I can actively prevent this?
The first photo is the .dxf file, and the second is the .3dm file with the dimensions I laid out
It looks like the problem is in reading the dxf back into Rhino 5, right?
Having the geometry and dimensions in a block and scaled x2 make things a little more complicated, but you’d have to adjust dimstyles after reimporting to get things back close to where they were.
