is there a way to insert drawing symbols such as depth, counterbore & countersink when using the drafting tools
Richie
Richie
Make a library of your symbols, then use Insert to add them to your layout.
Seems simple, did I miss the point?
Sorry maybe I was unclear. I wish to use the drawing symbol when I dimension, for example Ø6.5 depth 4.5, where depth is the correct geometric symbol (a down pointing arrow and line)
Hi Richie, It seems that I have exactly the same question. I need to find how to use in the same way as text the toleransing symbols (+/-) but one above the other, as well as the other drafting symbols diameter, angle, depth, concentricity,…etc.
Did you get any answer? or did you find any solution?
@pascal, could we request that the text creation box have buttons for a few widely used symbols: ⌀ ± ° etc.? I have an illustration program (not Illustrator) which does that.
Blacky,
As of this morning I have not had an answer or found a solution
Richie
Copy+Paste from Character Map? I know, it’s 2015…
or Alt+Codes
Also, see this:
http://forums.autodesk.com/t5/autocad-2010-2011-2012/annotate-depth-symbol-question/td-p/5132676
