hi there guys i’m trying to make this pattern in grasshopper but i have no single clue where to start.can you lead me to it please.
Try to figure out the smallest unit that you can then array or repeat. Try doing it in Rhino first, maybe import the image, then trace it with polylines and arcs. Watch for symmetry and dimensions. If you figure out the smallest unit and distances to copy, then it should not be hard to compose in GH. I hope this gives you a starting point.
I can strongly recommend this book if you’re really into islamic ornaments: https://www.amazon.com/Islamic-Patterns-Analytical-Cosmological-Approach/dp/0500270716/ref=tmm_pap_swatch_0?_encoding=UTF8&qid=&sr=
Cheers
Jonas
thank you so much Raja that did give me some thoughts
Jonas i checked it out. it was great and full of new patterns. thanks
