I have a c# component to pick two points and try to preview a line during the second GetPoint operation. The line only gets updated when I manipulate the camera and not when I move the mouse.
Maybe I subscribe to the wrong event?
private void RunScript(ref object A)
Rhino.Input.Custom.GetPoint getPt = new Rhino.Input.Custom.GetPoint();
getPt.Get();
basePt = getPt.Point();
// Preview Line for second GetPoint
getPt.DynamicDraw += drawMethod;
getPt.Get();
display.Dispose();
// <Custom additional code>
Rhino.Display.CustomDisplay display = new Rhino.Display.CustomDisplay(true);
Point3d basePt = new Point3d();
void drawMethod(object sender, Rhino.Input.Custom.GetPointDrawEventArgs e)
display.Clear();
display.AddLine(new Line(basePt, e.CurrentPoint), System.Drawing.Color.DodgerBlue, 10);
Surrounding code with three backticks ``` will allow for code to span multiple lines. The code block will try to automatically choose a style for code, but you can explicitly call out the desired formatting.
```cs
function foo(bar)
return bar+1;
``` Results in:
function foo(bar)
return bar+1;
If you’d ever like to see how someone else created their post you can use the following URL format to view the raw markdown https://discourse.mcneel.com/raw/{topicid}/{postid} take a look at my post as an example. Read More…
