Hi there,
I’m wondering if there’s a way to do something similar to the GetPoint.DrawLineFromPoint() function but instead of dynamically drawing from a point, it could dynamically draw from a curve with one end constrained to the curve (snapping to the closest point on the curve) and the other end following the mouse. Thanks in advance!
Hi @Sophie3,
below is a Python example which you might replicate using Rhino Common.
GetPointDrawLine.py (1.4 KB)
_
c.
Thank you @clement - that was very helpful!
Here is the C# version in case anyone is interested:
public class MyGetPoint : Rhino.Input.Custom.GetPoint
public Curve curve { get; set; }
public Line line { get; set; }
public Point3d startPoint { get; set; }
protected override void OnDynamicDraw(GetPointDrawEventArgs e)
double t;
bool success = curve.ClosestPoint(e.CurrentPoint, out t);
if (!success) return;
startPoint = curve.PointAt(t);
line = new Line(startPoint, e.CurrentPoint);
e.Display.DrawLine(line, System.Drawing.Color.Black, 2);
base.OnDynamicDraw(e);
var go = new GetObject();
go.SetCommandPrompt("Select Curve");
go.GeometryFilter = ObjectType.Curve;
go.GetMultiple(1, 1);
if (go.CommandResult() != Result.Success)
return go.CommandResult();
MyGetPoint myGetPoint = new MyGetPoint();
myGetPoint.curve = go.Object(0).Curve();
myGetPoint.SetCommandPrompt("pick a point");
//myGetPoint.DrawLineFromPoint(myGetPoint.startPoint, false);
myGetPoint.Get();
if (myGetPoint.line.IsValid)
doc.Objects.AddLine(myGetPoint.line);
doc.Views.Redraw();
return Result.Success;
