Drawing a curve on surface is sometimes very wonky
Why is InterpcrvOnSrf creating these wonky red lines? Is there a better command for drawing a curve on surface?
I tried to add more points to guide the curve, but they just became more distorted.
COS-wonkiness.3dm (271.2 KB)
(Just for clarification, the result I expected from COS drawing is what you get if you place a straight line at those end points and pull them to the surface…)
Hello - ShortPath may get you what you need here if the input is two points.
Here’s a version I like better because of the preview
ShortPathEx.py (2.7 KB)
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
Also - https://www.food4rhino.com/en/app/curveonsurface
Thank you for the tips!
But two points:
  1. Oh my dear lord, why aren’t both of those things built into Rhino? :laughing:
  2. In what scenario is the result I posted from my file desired behavior?
EDIT: Oh, that poor 6+ year old user made plug-in does not work on polysurfaces (but then again, not many McNeel commands do either).
So 8 months later I’m continuing this little project… and I’ve made a simpler example:
I still don’t see any scenario where the red line is the desired result. To me, this is a bug.
COS-wonkiness-2.3dm (192.5 KB)
