Double Spiral sculpture "Wonder" (up and down)
This is a cool double spiral sculpture by U.K. “Designer & Inventor” Tom Lawton. It’s on a rotating base so appears to go up and down at the same time. Done using parametric CAD.
ezgif.com-gif-maker_15
Needs refinement but not too bad…
wonder
full size
wonder_top
full size
Hello
There was a discussion on double spiral some time ago. But didn’t know it will give a nice effect when turning.
where were you was Laurent! :smiling_face_with_three_hearts: :blush:
Thanks, looks interesting and relevant but unless I get stuck, I don’t want to ruin the fun of discovery by looking at other code. :sweat_smile: I’ve made good progress and am pleased with how it looks. I have separate parameters for inner and outer radius (5 and 8), inner and outer “turns” (3 and 1 in this animation), ‘DivPts’ on the base circle (43) and height (15).
wonder_2023Aug27a
full size
Top view:
wonder_2023Aug27a2
full size
I suppose I should post the code but don’t want to spoil anyone else’s fun. :sunglasses:
Turns in this one are 2 (inner) and 1 (outer) with layers reversed in GIMP:
wonder_2023Aug27a4
Nice work Joseph. And thanks for making me aware of this sculpture
I replaced the Pipe with an elliptical cross section that twists based on distance from centerline. Not bad but doesn’t match some artistic details of Tom Lawton’s sculpture.
wonder_2023Aug27b
wonder_2023Aug27b.gh (37.8 KB)
In a different version, I’m exploring the Z coordinate of each perp frame (cross section), so it is flatter at top and bottom and steeply banked at the vertical middle. I’d rather avoid the complexity encountered in a recent thread, banking a figue-8 ramp.
in his sculpture, appears he has a total of 1.5 periods, or 1.5 revolutions’, of each spiral
Tricky, isn’t it? I’m not so sure. This is version ‘Aug27b’ with ‘Turns1’ and ‘Turns2’ set to 1:
This is a hasty hack that implements half turns, version ‘Aug27d’ with 1.5 turns for both spirals:
wonder_2023Aug27d.gh (44.1 KB)
