Double click on curve
Hi All,
was the idea for this topic rejected?
or for some conflict, as an alternative it was thought to use this system:
option mouse check: turn on control points?
ps it would be possible with the current UI?
0904 -
From RH-1810 (originally created on 2004-10-20):
Dale Lear - Commented 2021-04-22
This issue should be won’t fix. This is a request from more than 15 years ago and Mikko has done other things for easy-grips-on.
By default, points are now automatically turned on when a curve is selected.
Double-click to chain select the adjacent curves is the better option. I requested that long time ago. Pascal promised to implement it.
fyi: this works in Rhino 8 (if tangent)
Great to know that it is finally implemented. I will try it out later. Thanks. :smiley:
