Dots Printed in Vector mode have transparent text and are malformed
Please refer to attached pdfs. DotRaster.pdf shows dots properly, DotVector.pdf has problems. The white text should be opaque and should be centered in the black rounded rectangle. Rhino file and system info attached as well. Thanks!
sysinfo.txt (14.5 KB)
Dot.3dm (96.8 KB)
DotRaster.pdf (322.0 KB)
DotVector.pdf (17.7 KB)
Hi Kaleb,
Thanks for the files. i can see it right in your DotVector.pdf — the white text isn’t opaque and the second line lands outside the dot border, while the raster output is correct.
This is filed as RH-97024 Print: Dot text transparent and mis-centered in Vector output. Thanks for reporting, the small example file made this an easy one to pass along.
Thanks Japhy!
RH-97024 is fixed in Rhino 8 Service Release 36
