RHINO 8 annotation dots printing problem
There is problem to make a pdf print of annotation dots. This happen when vector output is required - the dots are blank at the exported pdf (even no very small text). If raster export is choosen, all looks normal on the print. I tried several setting, but no success. It’s the same in WIP, beta and final release of Rhino 8 for Mac.
It’s the bug or I do something wrong?
hi @frantiska.bakosova does this bug report represent what you are seeing?
RH-78147 Unreadable text in pdf output
I think yes … sorry I did not find this ticket …
For addition:
  • in the printing dialog, there is in the preview the text upside down when “vector output” is checked, versus “raster” what looks ok.
  • I tried to open exported pdf in other editor, and I think there is no “unreadable text” but no text at all, just shape of the dot.
that’s because I made that after your report :wink:
that one I reported as RH-78145 TextDot shows larger in Vector preview and inverted
Is there any resolution to this? I’m having the same problem. If output is vector, the text dot is upside down.
hi @Norma_Katz As soon as this is fixed, this thread will be notified.
Thank you. I’m really loving the section/drawing improvements in V8. A few glitches but really nice.
