Hello all,
I really dont know how to explain my proble because i dont really know whats going on, so i will try to explain it…
This is strange issue is happening me in just one model. I have used Rhino 5 to model it, as i allways do. And when i finished it modelling i exported it to 3dmax and i discovered that what it thought it was a perfect surface, on reality it was a bunch of weird meshes! I am sure you will understand it better if i attach a few images where i explain step by step my problem…
1st. Here goes the windows of my building… This is just one layer that composes my model… Its just the glass i created extruding a rectangle. It seems ok, right?
2nd. I select just one glass to show you the proble that occurs in every object in the model… In rhino 5 i dont notice it unless i analyze it or open it in rhino 4 or 3dmax 2012 or 3dmax 2015. The glass seems perfect… a closed polysurface composed of 6 surfaces.
3d. Everything seems normal… but if i analyze the curvature (?) of this plane surface the weird stuff begins… Where did my plane surface went??? I just extruded a curve…
4th. Ok, dont panic, mayby its something wrong with the visualization parameters…Please show me the mesh wires…
5th. I dont really now whats going on and what is wrong. I dont know what to do. So i open grasshopper to check this issue… It confirms me what rhino jsut told me…
6th. And this how rhino 4 shows me the model… In 3d max is even stranger… I have never seen anything like that…
I would appreciate a lot any kind of help solving thi “issue”…
Thanks you very much in advanced,
Daniel
