Does Rhino 8 support old KeyShot 9 plug in?
Hi - Does anyone know if the old KeyShot 9 plugin works with Rhino 8 on WIndows 11 ? (Works fine with Rhino 7). It’s legacy rendering software I know, but I use it every day and I won’t move to Rhino 8 if it means losing my favourite renderer.
Thanks !
I’m using Keyshot 9 too but already gave up on the live link in Rhino 7 because Keyshot 9 didn’t import SubD.
Hey Martin - Workaround for your problem is to convert the SubD to NURBs (“ToNurbs” command - it makes a Nurbs copy)- and then send the NURBs version to Keyshot 9. If it’s a really complicated SubD the NURBS version can sometimes need a little tweaking, but it works.
You’re right.
_ExtractRenderMesh works too
The plugin works in Rhino 8 and Windows 11
I just installed it again and it works fine in Rhino 8 on Windows 11
Thanks Martin. Did you test the plugin?
Yes.
Thanks for your help ! Solved.
I knew there was another reason I stopped using Keyshot 9… GPU rendering is not supported anymore:
Windows 11 Does not support Nvidia drivers below 471.XX : KeyShot
Works fine on mine but not with the latest Nvidia driver - I had to roll back to an earlier version - 531.41 (Nvidia). Also depends which drivers your graphic card hardware supports…
I’m using the latest drivers.
Try rolling back to 531.41
Dear Martin, I am looking for the plugin to import rhino 8 files in keyshot 9 can you send me a link?
Piergil
Look here:
Previous KeyShot Versions - www.keyshot.com
