Does gtx 1650 mobile Good enough?
Hello. I am a student and at the start of learning Rhino. I don’t want to buy an expensive system at first so I will buy a laptop to start learning. I chose HP victus laptop that I think is enough for beginning. specs:
CPU: Core i5 12450H
GPU: GTX 1650 4GB
Ram: 16GB
(https://www.amazon.com/dp/B0BL1L4MBV/ref=twister_B0BL1L68LX?_encoding=UTF8&th=1)Full specs
I will change it when i become a pro user so is it good for the beginning?
and i don’t plan to use the second monitor.
Our friend @gkirdeikis uses it in his YouTube channel and works well.
Make sure to subscribe and learn.
Thank you very much.
Check the other prices
There’s also a 32GB Ram version that could be a good option.
thanks
Are these video cards using shared memory? Whenever I don’t see the GPU ram that’s my first assumption. I would go for the 32GB if the memory is shared.
