Here I am proposing an improvement for the documentation of the method:
Mesh.CreatePatch(Polyline outerBoundary, double angleToleranceRadians, Surface pullbackSurface, IEnumerable<Curve> innerBoundaryCurves, IEnumerable<Curve> innerBothSideCurves, IEnumerable<Point3d> innerPoints, bool trimback, int divisions)
It is common to encounter hidden contraints about data intensive procedural APIs that has not been documented yet. While I was working on meshing non-manifold special structural geometries, I encountered a hidden constraint about the inputs of this method that I think it shall be mentioned in its documentation. Improving documentation shall be also responsiblity of the community to reduce vaste of precious time of developers.
Proposal:
the section about “innerBoundaryCurves” input of the method can be improved as such:
// innerBoundaryCurves:
// (optional: can be null) Polylines to create holes in the output mesh. Each curve shall represent a hole and shall be in closed form If innerBoundaryCurves
// are the only input then the result may be null if trimback is set to false (see
// comments for trimback) because the resulting mesh could be invalid (all faces
// created contained vertexes from the perimeter boundary).
